Old 01-09-2012, 12:10 PM
mtomac mtomac is offline
Default engine ID for a 1985 cub cadet 782
would this kt17 be a series 1 or series 2
Old 01-09-2012, 01:39 PM
BCDSFCRET BCDSFCRET is offline
Default Bcdsfcret
Should be a series 2
Old 01-09-2012, 03:40 PM
The serial number of the motor is: 14184479
Old 01-09-2012, 03:50 PM
Can you find the spec number on the engine?
Old 01-09-2012, 04:03 PM
That puts it in 1984.
Old 01-09-2012, 04:07 PM
For a Series II, the spec number will be 24300 or higher, the air cleaner and flywheel shroud will say "Series II", and the oil fill will be a plastic cap instead of a large metal pipe plug. It also may or may not have an oil filter blockoff on the lower right side of the block near the front. It would also probably have a Walbro non-adjustable carb.
