Old 01-18-2012, 11:09 AM
Donny Curtis's Avatar
Donny Curtis Donny Curtis is offline
Default 3 pt and Brinly hitch
Got this on a trade, just making sure I got everything I need, other than a good cleaning up,to put on a 1650 frame, I have a hydro lift pump
Donny
Old 01-18-2012, 11:32 AM
cub123's Avatar
cub123 cub123 is offline
Yup, looks like you have everything!
Old 01-18-2012, 12:12 PM
Good trade, Donny! Can't wait to see it on your 1650.
Old 01-18-2012, 01:46 PM
Donny, sorry for the delay in getting back to your PM. Here's some links for you.
Hitch and rear lift diagrams.
http://www.onlycubcadets.net/forum/showthread.php?t=4
Here's a link to the operators manual pages 16 and 17 have the hitch info.
http://www.onlycubcadets.net/forum/s...ead.php?t=4670
Here's the install manual for the hitch. The manual is for the 1x8/9 tractors but the info should be the same.
http://ccmanuals.info/pdf/WF%203PT%20Install.pdf
You'll have to remove one rear tire to get the top casting installed. You'll have to remove the tunnel cover as well.
Old 01-18-2012, 01:47 PM
MrGitrdone41's Avatar
everything is there! On your 1650 do you have the frame spacers welded on?
1988 1812,dual ports
1973 108
1968 125
Old 01-18-2012, 02:00 PM
If no spacers you will need two Frankenstein bolts to attach the rockshaft with.
Old 01-18-2012, 05:05 PM
Thanks Guys, thanks for all the feed back, now to get time to put it all together, starting from frame up I hope, have a 1250 total tractor with a blown engine, hope it is just the rod, like He tought it was, also have a 1650 frame going to take two to make one, have a front blade and dual tires to put on it. But now to get time
Donny
Old 01-18-2012, 07:03 PM
Nice lift and hitch
