Old 01-19-2012, 06:00 PM
samiam44 samiam44 is offline
Default what's a K341AQS weigh?
Does anyone have a good weight for the engine + starter?
Michael
Old 02-01-2012, 01:32 PM
Mike1450's Avatar
Mike1450 Mike1450 is offline
My K321 after I rebuilt its weight was ~190lbs complete with Muffler, PTO and all tin on it,dry (no oil) I would not think the K341 would not be much more.
Old 02-01-2012, 06:42 PM
Barnabas Collins Barnabas Collins is offline
That should be in the ball park..the 16hps weren't any bigger, just had a bigger hole inside. If you think about it that way, substituting iron block for aluminum piston, it might be a touch lighter! (the extra head bolt probably evens that up though)
Old 03-20-2012, 01:28 PM
Thanks..~ 200 lbs or 50# per mount.
I think there are some off-the-shelf isolators similar to the original QL mounts available.
