Old 01-20-2012, 04:14 PM
rogers rogers is offline
Default 450 -451 snowthrower
Are the gear boxes on the spiral or auger interchangeable from a 450 to a 451 snowthrower? I have already changed the back outside gear box and woundered if the spiral box shound't be changed also. I have a some what altered 451 on a 782D.
Old 01-20-2012, 05:59 PM
riesedesperado6170's Avatar
riesedesperado6170 riesedesperado6170 is offline
they are the same
Old 01-20-2012, 06:16 PM
The worm drive gearbox that runs the auger is probably the same; the other one definitely isn't. The ratio in the other gearbox is basically the difference between a 450 and a 451.
Old 01-21-2012, 01:50 AM
Not sure if this helps but from the FAQ section of the site.
http://www.onlycubcadets.net/forum/s...ead.php?t=7866
