Old 01-20-2012, 11:46 PM
72-149's Avatar
72-149 72-149 is offline
Cool Beet juice in the 26x12x12 true powers
i paid $70.69 to have two 26x12x12 true powers filled with "RIM GAURD" 8 GAL. per. wheel & 17 PSI.in ea. .what a difference from the turff's the 982 is a monster now cant waite to get chains & 300LBS. on the back & wheel weights.the weight of the tire & rim & tube & rim gaurd 130LBS. per. wheel (260LBS.for both)i also put the ag's on the front it dosent slide any more like it did with the turff's on front.
Old 01-20-2012, 11:55 PM
johncub7172's Avatar
Where did you find Rim Gaurd at? I want to load my Tru Powers with it too!
Old 01-21-2012, 12:37 AM
John, from rim guard site.
Need to find a dealer in your area? Give us a call at 866-792-3700 and we'll locate a dealer near you.
Old 01-21-2012, 02:11 AM
72-149's Avatar
Yep that's what I did. I called them & they asked my zip code and they told me who had it. The price varies from $2.00Gal. to 3.50 Gal .I went to Buffalo Tractor on Seneca St. in West Seneca NY
Old 01-21-2012, 07:27 PM
Very nice! Your 982 is looking good! I bet, you can go almost anywhere now.
Old 01-21-2012, 07:39 PM
Looking good. The beet juice in my rear ags definitely makes a difference and will try to put it in any cub I get from now on.
Old 01-21-2012, 07:52 PM
MrGitrdone41's Avatar
I'm going to put it in my 1812 tires and see how it goes. I had water in them in the summer and it went good but still spun lol! I found on sears.com you can get 55lbs wheel weights for 50$. I might have to buy a set.
1988 1812,dual ports
1973 108
1968 125
Old 01-22-2012, 05:04 AM
72-149's Avatar
rim gaurd is heavyer then water is 8LBS. rim gaurd is 11LBS.
72-149's Avatar
like a little tank !!!
Old 01-22-2012, 06:07 AM
daved5150's Avatar
daved5150 daved5150 is offline
Hey Bob. Buffalo Tractor was one of the places I called for Rim Guard. They charge you one hour of shop rate I believe. There was another place in Collins I believe that was a little more than Buffalo Tractor. I went to Tri County Supply on Route 16 in Chafee and they only charged me around 20 bucks for 23" tires. I had to buy new tires because the old ones had tubes in 'em. They p****d me off because they threw out my old tires after I told them to save them. If my tires weigh around 75# a piece, yours are definitely more. I've got one set of IH wheel weights and tire chains from tirechain.com. Anyone looking for tire chains for anything, this is a good site to go to. Last year I was spinning the tires like crazy, this year...nada. But I'd still like to get more weight. Very nice 982. Your 149 was still sweet though.
I see you got that Meyer plow mounted....SWWWEEEETTTTT!!!!
