Old 01-21-2012, 11:52 AM
nutzboutoldies's Avatar
nutzboutoldies nutzboutoldies is offline
Default Cab and rear fenders
The rear fenders on my 1450 are cracked at the bolt holes that were drilled for the cab mounts. I would like to repair the fenders and prevent this from being a recurring problem when I reinstall the cab. Has anyone had this problem and is there a fix, or maybe a reinforcement part available for this?
Steve
1450
QA42A Thrower
44A Mower
Old 01-21-2012, 01:06 PM
Shaner Shaner is offline
maybe take the fender pan off the tractor, and spot weld a few washers underneath the fender pan where the holes are. this way, the bolts that hold the cab on will be tightened against a washer instead of the sheet metal. the washers will be under there, but not visible on top of the fenders.
