i need to build a stack with a one inch bottom welded to a 4 or 5 inch pipe and a 45 degree curve. any suggestions?
1965 Cub Cadet Model 71. "If it ain't yella, sell a" MADE IN AMERICA ![]()
Search on stacks. There's a thread on them and that may help you get some ideas. If you have some pictures that might help too.
Regards. Chris
Casbohm Maple and Honey www.mapleandhoney.com Cubs: 147R and the "train", 127 elec lift, 127, 125, 106, 102, 100, 86, 73, Brinly plow, Snow thrower, 2 Rototillers, several mower decks and several snow plows, #1 cart, Grandkids barrel cart. |
Looking forward to your progress on this project!
This is what I have right now. I want to weld the end of that pipe to an expander and then weld that to a pipe. I just can't find a one inch expander.
i was wondering if theres any other options.?
You could step it up with pipe couplings or have a local machine shop make a adapter plate the size you want and put the 1 inch pipe thread in it.
Regards, Chris
Make sure you brace your stack to a head bolt or something good and strong so it don`t get broke off in the block.
Jed Proud to be a FFA member Westmoreland,TN Chapter 1978 Cub cadet 1450 IH Hubcaps 1975 1650SGT Work In Progress 1974 cub cadet 129 with sleeve hitch/spring assist 1974 108 (Mint) #510358 brinly 12 in plow,disc,8 in plow ,2 42, 2 44A ,50A DECKS #40 boxblade,can`t keep up with the rest lol ![]() ![]() ![]()
I just put a stack on my 128
posted in HOMEMADE section http://www.onlycubcadets.net/forum/s...ad.php?t=15268 I used 2 1/8 auto exhaust connectors I liked them because it kept the assembly lite. My project cost me $25. If you had access to a large conduit bender the 1.5 or 2 in conduit might work well . ![]() 128 plow , disc , rake , s blade , scraper |
I bought a dead puller with some type of factory built stack. (Ok double stacks but you could just do one.)
Personally, well..to each his own. Here is the bracing that this stack came with. If it could hold up these two tall stacks with all that jerking around and no problems, then bracing this way must work well. (I'm debating whether to throw it away or list it on ebay.) |
| Tags |
| stack |
