Old 01-23-2012, 11:25 AM
roaf3 roaf3 is offline
Default Shifter replacement in 124
Hi guys,
Does anyone know what oil goes in the tranny?
I am putting the shifter back on and there is 1/2 ++ inch of oil on the bottom.
I am assuming there should be a little more?
Any thoughts are appreciated.
Roy
Old 01-23-2012, 11:29 AM
It's probably time to drain the old oil out and put in some fresh. It takes Hytran from Cub Cadet.
Fluid link: http://www.onlycubcadets.net/forum/s...ead.php?t=4634
Amounts: http://www.onlycubcadets.net/forum/s...ead.php?t=4673
Service Manual for your 124: http://www.onlycubcadets.net/forum/s...ead.php?t=4642
Old 01-23-2012, 12:46 PM
Many thanks as always.
Roy
Old 01-24-2012, 10:46 AM
If I dump the current fluid. Is there any reason I cannot fill through the top of the shifter plate before I put her back together? hat seems easier than pumping.
I assume the axle would gravity feed?
RD
Old 01-24-2012, 12:25 PM
RD
No reason that you can't do it that way.
Old 01-24-2012, 12:41 PM
Excellent!
I am thankful for the advice as when I drained the tranny over 25% was pure water as it had been sitting for a couple of weeks.
Amazing !
Roy
Old 01-24-2012, 01:45 PM
Excellent!
Amazing !
Roy
Roy, your welcome and that's a lot of water! Glad your finishing it up so you can start enjoying it again.
Old 01-24-2012, 04:50 PM
Well said!
