Old 01-23-2012, 11:29 AM
cub123's Avatar
cub123 cub123 is offline
Default '61 CCO question
After thinking I ran the numbers on my O wrong for the last few weeks, I went and did it again. I keep getting that it's a Dec. 61 , but after seeing that it has no creeper hole, has the old style S/G and bracket, and also a small hitch hole, I know something is wrong, am I reading the right number? Im running the one on right side( sitting on tractor) on the reduction housing. It starting to bug me, only other thing I could think is it had a tras swap, but it doesn't look like it ever been changed
Old 01-23-2012, 11:48 AM
mmzullo mmzullo is offline
Pictures of the serial #??
Old 01-23-2012, 12:03 PM
cub123's Avatar
Here ya go ,# is 21xxx
Old 01-23-2012, 09:32 PM
That's a late 61 or early 62. I'm not sure when they started to put the creeper holes in the frame. But the early parts don't really mean much.That's still within the first year of production.
Old 01-23-2012, 10:02 PM
Ben, the early SG brackets ran out before the creeper holes from what I've been told. When there was a problem tractor that failed post inspection they would roll those tractors to the side and finish them when they got the chance to. The serial numbes were the last thing to go on them before they shipped. It's very likely that yours got rolled to the side and got repaired at a later date. You have to keep in mind that they sold more tractors in the first year then they planned to sell total for production run. There were tons of changes thru out the production life.
What does your battery tie down look like?
Old 01-25-2012, 02:07 PM
cub123's Avatar
Here's the batt tie down, just a normal tin one.
Old 01-25-2012, 02:50 PM
So I see. Ok next request. Does it have collard spindles? If so can you take a pic from the rear of the tractor to the front.
Old 01-25-2012, 04:36 PM
cub123's Avatar
Here ya go, I don't think they are the Collard type though.
Old 01-25-2012, 05:06 PM
They are not and you don't have the thin front axle but those were recalled so it's not shocking that they are not on there.
Now comes the question did someone try to make a early 61 or is it a hold over from production problems.
Could you take a pic of the fins and spec and serial number of the motor. The motor might have been replaced but it's something to look at. Even after all of this we might never find out the real reasons for this to have signs of a early 61.
Old 01-25-2012, 05:34 PM
cub123's Avatar
Ok, thanks. I'll get some pics tomorrow, I guess it was still worth the $200 I gave for it though LOL
