Hello. I have a 1650 and have been planning on putting a snow thrower on it. I know I need QA-A. I have found a QA42-A. It was on a JD 318 and owner has sence bought a JD blower for his. I am not sure if mount brackets have been changed or not but it does have hydro lift on it already. I plan on taking my 1650 with me to make sure if it fits.
QUESTION!!! I do not plan on using mule drive and mower deck on the 1650 ever. Now..... Can I disconnect the hydro lines from the deck lift cyl. and extend the hozes from the raise/lower switch/lever from the stock hyrdro pump/valve (sorry not sure what im saying) (i hope all this makes sense as I am half asleep right now) to the raise/lower cyl on the blower and to be able to raise and lower the blower? No plans of adding rear attachments either. Thank you !!!!!! John |
If somebody kludged it onto a JD, your guess is as good as mine or anyone else's as to whether or not it'll still fit correctly on your Cub. I'm going to guess you'll have some mods to undo.
There is no reason to do what you are proposing to lift the snowthrower...just run a lift rod from the lift arm on the right side of the tractor to the lift arm on the snowthrower as shown in the manuals available on this site and also numerous pictures that can be found here. The tractor is already set up to raise and lower the snowthrower as is...no need to have a lift cylinder for every attachment like most JDs... |
http://desmoines.craigslist.org/for/2783976106.html |
aww crap now someone else will see it and buy it out from under me!! ahhahaha
I got to tell you for $500 let them have it. Looks to me like a whole jd drive system has been cobbed on to it. That is rediculous money for a QA-A thrower. I would bough out of that one. Just my 2 pennies.
1641, 1541, 682 with 18hp command engine and hydraulics from a 782. 1872 with a power angle blade. |
$125.00 tops for that!! If you remove the hydro lines for the lift how are you going to lift the blower?
Qa 42 snowblower. Just because its painted John Deere yellow does not make it worth $500. I would not pay more then $50 for it.
Pass on that. I bought mine for $150 and it still has the original paint and stickers - still shiny, as a matter of fact. Something better is out there.
CCC 784 w/ Triple Hydraulics IH 982 Cub Cadet Commercial H1748 Walk-Behind 50C Deck 42" Hydraulic Angle Front Blade 41" IH Rear Blade QA42A Snowthrower |
I agree with the others. Way over priced. Leave it sit. You should be able to find a nice one, ready to use here in Iowa for $150-200. It's been pretty cobbled up and painted Jane Doe "Gold".
![]() Keep your eyes peeled, something will show up for ya!
Josh Diesel Cub Cadets........... |
Thanks guys!!!! Yea thought it was little over priced but have not been able to find one yet. Was just happy to find one sitting around and yes John yella does suck.. didnt even think about that!!!
THANKS!! Anyone have any source ideas in iowa area on one?? THANK YOU!!!! THANK YOU!!!! THANK YOU!!!! John |
