Old 01-31-2012, 07:22 PM
Default 1861, Defective Switch, or Normal!!??
On my 1861, you can lock down the brake pedal, then without sitting on the seat, turn the ignition switch and the engine will turn over.
I got that!!
The problem is the engine will not start!!
The seat switch must be engaged (you got to sit on the seat) for the engine to get spark!!
I have a hard time remembering this!!
This happens to me this time of the year, the battery is run down, I am running around making sure the jumper cables are hooked up, carb getting gas etc...., I forget I got to sit on the seat or the engine will not start.
Is this normal or do I need to replace a switch!!??
Old 01-31-2012, 07:23 PM
I got that!!
Normal
Old 01-31-2012, 07:55 PM
Normal
Most people tell me this 1861 is anything, but, normal!!
Old 01-31-2012, 08:24 PM
Dave01's Avatar
Dave01 Dave01 is offline
Duke, are you sure of that? On my 1864 I can start it with the brake pedal down, but I'm not in the seat. The seat switch does work, will kill the engine if I get off without pushing the brake down. I'm thinking his brake switch is faulty so without being in the seat it won't start.
1864 w/48" deck, 2084 w/54" deck + 54" blade, 3204 w/48" deck
Old 01-31-2012, 08:42 PM
cubs-n-bxrs's Avatar
Ditto what Dave said. My 1641 is the same way. I can lock the pedal down and start it without being on the seat.
Old 01-31-2012, 10:15 PM
Dave01's Avatar
CAD, I'd look at the brake switch. I have a feeling you'll either find the bracket loose so it doesn't get depressed, or the switch is faulty. If you are running, and set the brake, and then get out of the seat does the engine shut off?
Old 01-31-2012, 10:59 PM
Loose bracket/switch sounds very possible. I seem to remember last summer occasionally the brake pedal needed a couple tries to allow the engine to run while off the tractor.
That is just something I don't remember for months.
The 1861 runs/functions perfect as long as you are in the seat. I don't expect it to stay running very often when I am not in the seat.
Old 01-31-2012, 11:04 PM
Dave01's Avatar
I find myself picking up stuff in the yard, could be sticks or similar, or items the kids left in the way, so I shut off the deck, throttle down, set the brake, and get off rather than shut down the engine every time. I'd find it really annoying if the tractor shut down every time I got out of the seat!
