Old 02-01-2012, 09:58 PM
VIOLATOR VIOLATOR is offline
Default o-rings
Howdy. I am going to replace the o-rings on the relief valves and the question I had was do I need a special type of o-ring or can I use the ones at the hardware store? Will the hydraulic fluid eat away at them?
Old 02-01-2012, 10:19 PM
As long as they are the correct size that should be fine. I have never heard that they were a special O ring, but I haven't had to replace any either.
Old 02-01-2012, 11:00 PM
Originally Posted by VIOLATOR View Post
Howdy. I. Am going too replace the o-rings on the relief valves and the question I
Had was do I need a special type of o-ring or can I use the ones at the hardware store. Will the hydraulic fluid eat away at them.
There are special o-rings that can handle the hydraulic fluid. Contact a local hydraulic store near you and get some. When I was in QA we had to keep track of which o-rings were used.
Old 02-01-2012, 11:09 PM
Ahh, ok, that is good to know. Just hoping I don't have to worry about that for awhile. And when it does I'll probably mess up and get the wrong ones anyway... LOL
Old 02-04-2012, 09:32 PM
Thank you for the advice.
