Old 02-05-2012, 09:02 PM
Daniel.Donaldson Daniel.Donaldson is offline
Question Vanguard engine swap
I was thinking about doing a 14hp vanguard engine swap on a 128 but I can't think of a way to mate the driveshaft to the crankshaft of the enigine. Does anyone know how to do this or have any advice. I am fairly new with working Cub Cadets or any riding mowers. Just a teenage weekend warrior hard at work!
Old 02-05-2012, 09:10 PM
Let's see some pictures of your 128!
Old 02-05-2012, 09:28 PM
JaysNJcub127's Avatar
JaysNJcub127 JaysNJcub127 is offline
Default this guy
http://www.jimsrepairjimstractors.com/Engines.htm
has kits for cubs
1969 Cub Cadet 127
Cub Cadet HDS 2155 w/ bagger
#2 IH cart
48" deck
42" Front Blade
Brinly Sleeve Hitch and Brinly Plow
IH wheel weights
Old 02-05-2012, 10:50 PM
I'm in Statesville. Lots of us here from NC.
Old 02-06-2012, 11:40 AM
thanks for the link JaysNJcub12! Awesome Methos, I'm near Monroe! I'm going to try to get some pics soon, but it doesn't have an engine yet, duh.
Old 02-06-2012, 12:23 PM
Welcome to OCC, Daniel! I'm near the Fayetteville area. Looking forward to your pics.
Old 02-06-2012, 12:50 PM
jbrewer's Avatar
jbrewer jbrewer is offline
And I'm near Clayton.... welcome to OCC!
John
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 02-06-2012, 12:54 PM
Lots of cub and garden tractor nuts in that neck of the woods!
Old 02-06-2012, 08:05 PM
Dan
First about the adapter for a Briggs to Cub shaft. I used Cub part # 719-3096 for the adapter on my swap and you'll also need Cub part # 711-3330 pin. The pin goes into the hole in the center of the crank to locate the adapter. These are numbers from a Cub 2160 with a 16HP Briggs. Think they run under $40.00 Looks like it's the same numbers they use for the Kohlers. The bolts holes are sloted so my guess is it will fit both engines hence the locating pin to center it.
Second I'm in Galax VA 3 miles from the Blue Ridge Turnpike, this area is motorcycle nervana at least it is for me.
Sam
Old 02-06-2012, 08:45 PM
Dan
Sam
That's not going to work on a gear drive. A custom adapter will be required.
