Old 02-06-2012, 09:11 PM
ihcfanatic ihcfanatic is offline
Default 124 Diesel Conversion
Has anyone attempted to install the Kubota D600 in a narrow frame, if so I need plenty of advise and/or pictures.
Thanks!
Old 02-06-2012, 09:20 PM
ANYTHING can be done, but, after hearing the difficulties of accessing the driveshaft with the NF, I would attempt the swap with a removable tunnel cover machine.
But, if you do finish the conversion, you will have one cool machine!!
Old 02-06-2012, 09:32 PM
TheIHMan's Avatar
TheIHMan TheIHMan is offline
You will have to have a custom radiator because the right one is too wide for a NF. Also you will have to make a custom fuel tank and battery box, but anything is possible.
Old 02-07-2012, 11:12 PM
AMCJavelin74 AMCJavelin74 is offline
I swear I saw a picture of a IH CC of some sort with a CC yellow 2 cylinder Perkins diesel sitting next to it waiting to be swapped in... it was over at my tractor fourm... can't seem to find that picture.
...maybe I was dreaming.
CC 128 (Sept. 74)... and other vintage non-CC LT/GTs.
Old 02-12-2012, 08:16 PM
I remember seeing that one on MTF also. May have had a Cat name on it cause Cat was selling Perkins labeled as Cat's
Old 02-12-2012, 09:33 PM
gcbailey's Avatar
gcbailey gcbailey is offline
I've saw a few with single cyl yanmar diesels, or some cheap chinese diesel put in that's pretty close to some of the kohlers. Nothing bigger than that on a NF.
Gary
