Looking for a diagram. I can not find one so. I'm going to make one. Can anyone please help with measurements? It is the bar from lift handle to the sleeve hitch with a little bend in it. Thanks I am sorry it is a 108 wide frame
Zander NC 72 108 12inch brinly, tandam disks, slave hitch & counting.
It would help to know what model of tractor you are referencing..??
Alexander/is the lift on a Quietline series or 82 or which one? heres the Quietline measurements, a member here gave them to me.
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake!
It is a 108 I am new at this . Everthing is clear but the 3/4 holes on the end how close are they to the end Thanks bocephus
dont forget about the bushings for the 3/4" hole , to take it down to the 1/2" bolt that holds it on. Jeff in Pa is making them for me.
HAY Look ,,,, my first helpful post.....
Doug Original , 100 , 125 , 582 ![]() ![]() ![]() ![]() West Central Ohio Farmall & Cub Cadet Club https://www.facebook.com/#!/groups/226681087497199/ |
If that bar is for the quietline i need one. I cannot make out the dimensions. Is there a clearer picture out there? There is also a block with a round boss and 2 threaded holes too also correct? Any drawing for that? I have a 1650 that i need to put a lift on. So I need the rear piece that is cast. I would like to make it but I have nothing for reference right now to build it off of. I have a waterjet that I can plug in the dimensions and have that bar wacked out quickly. So there is a bushing that needs to be made also? Is the bushing steel, oil-lite, bronze? Which hole does it go into?
Hey that's my drawing!
Here's a closer look. |
