Old 03-05-2012, 09:58 PM
cavmedic cavmedic is offline
Default Confessions of a 1450 upgrade.
Tonight I arrive home to a package from UPS. Inside is a upgraded engine cradle, new iso mounts and cast iron oil pan from Patton Acres. I'm all happy, the dog is happy to see me. I take about 15 minutes to throw the Frisbee with him and get him some exercise.
I go to the car, grab the 2 gallons of Hy-tran for my hydro change and head up to the garage. I already have the 1450 up on jack stands minus front wheels , as I dropped them off at the shop this morning to have new tires, wheel bearings , tubes and fluid installed. I start organizing my parts as I am about to do a front hydo output upgrade while the engine is off the frame.
Everything is going ok , I get the fuel tank and that separator thing off, get the hood and front cowling off, start removing wires that need to be removed and run into the first snag. When I bought the tractor last week , it had a few small issues with wiring. There was lots of wire nuts, spliced solid conductor wire on misc parts. So, I went through and redid all the splices and soldered them. Ok , so I now have to cut some of these wires. No big dea , I'll just re-splice , solder and shrink. Not a big deal.
Now I'm to the point where I need to take out the motor. I start fighting with the ISO mounts , trying to reach the nuts under odd parts of the motor , contorting , hanging upside down and twisting every which way . I was getting a little frustrated, so I stepped away. I went in the house to talk to the wife as she just got home from work,. About 15 minutes and 3 Alieve later , I go back to the garage , think for a few minutes about what engineer came up with this stupid A$$ design when I realize that I didnt have to go through all that when there was 3 bolts in the oil pan that would release the motor from this contraption. Now I can't say for sure if that is the right amount or not, but that is what was there.
So after that, I'm able to lift the engine out and set it on the floor out of the way and proceed. Mind you this was a dead lift. I KNOW I am going to feel this tomorrow especially after a 3 level cervical fusion and a artificial disc in L5 within the last 5 years.
So after I get the new cradle and iso mounts in , i move to the hydro portion of this upgrade. I get the old spool valve out , the old lines disconnected , mount the mounting plate on the steering column , start lining up lines to see how they route to the pump and which end goes where , all is going fairly well up to this point in the evening.
I remember saying to my self that this is going pretty easy for one of my projects. Something ALWAYS turns to crap somewhere along the line. So I continue to study some stuff here and there , reach up and look for the pin on the lever arm to release the arm and pull it out of the tower to install new parts and there it was. There was no roll pin , it was a cotter pin. I thought wow , for a cotter pin, there was no play in this what so ever. Well, when the linkage wouldn't slide off I grabbed the flashlight and found out why. Someone welded the linkage to the lift handle .. WTF over ! . Seriously , instead of replacing the roll pin that obviously fell out at sometime , they went up in there with a stick welder and went crazy. It's not even decent, its like the worst blob solder job I ever saw. GRRRRRRR . So I decided it was a good place to pack it in for the evening and get cleaned up, curse a bit more and grab some chow. I have to figure out if I'm either going to get up in there with a right angle grinder and cut the old handle or if I'm gonna need the sawzall.
I really hope the cradle and iso mounts get bolted to the frame first , then the motor gets lined up and can be bolted to the oil pan last.....
Old 03-05-2012, 10:25 PM
You should put your cradle mod in and correctly tighten your ISO mounts up. This makes putting the engine in a lot easier.
But...as far as the other stuff, sorry to hear about your troubles. No sense in getting too upset about it. Keep on trucking and youll have a decent Cub to mess with
Old 03-05-2012, 10:45 PM
My buddy is going to bring over a small chain hoist for me to rig up. Wrestling that by hand is not cool . Gotta work smarter not harder.
I gotta fresh day tomorrow to start again back atcha
Old 03-06-2012, 02:08 AM
As already said the engine cradle goes in first then the motor. Some PO's do some really dumb stuff to them. I've got to do the ISO mounts on my 1650 and I think I'm going to use the FEL to help me out with that back breaker.
Keep at you'll get it!
Old 03-06-2012, 06:47 AM
It would probably go a bit easier with a real garage , real electric service , level floor , heat and some tunes , but I'm stuck with what I have for now. I'm also in the process of finishing the basement in the house, so my extra furniture is being stored up there taking up ALLOT of room . I have a temp electrical service to give me basic lights . In about 10 years , I can build a real garage.
Right after I pulled the motor.
Old 03-06-2012, 07:32 AM
maddog784's Avatar
I usually don't consider it a project until I run into a snag or two. Needless to say, I've got a couple of projects!
CCC 784 w/ Triple Hydraulics
IH 982
50C Deck
41" IH Rear Blade
QA42A Snowthrower
Old 03-06-2012, 07:35 AM
One good thing is I now get a good chance to really hit this thing with the pressure washer and some simple green and clean the crap out. Just gotta wait until my tires are done so I can move it easier
Old 03-06-2012, 10:06 PM
O)K , tonights update. The grinder didn't fit into the tower so I had to resort to the sawzall . The only casualty was a terminal broke off of the headlight switch rendering it useless. The good news is , I disliked that switch anyway. I plan to panel mount a SPDT switch , so I can hook up a rear work light . Up headlights , middle off and down headlights and work light.
Now , can someone tell me if I have the hoses to the lift cylinder correct ? I want them so when I pull back , the lift goes up. I think I got it correct but I'd rather know now before I start putting stuff back on ...
I am assuming that when I pull back , it lifts the plunger , opening the flow to the bottom , extending the ram . Then when I push front , it pushed the plunger down , allowing for flow through the top of the spool valve , compressing the ram back in ..
Also another thing I noticed from a PO repair , lets see if you eagle eyes catch it
Old 03-06-2012, 10:08 PM
Wow, I never thought about using hose clamps for that before. LOL
Old 03-06-2012, 10:12 PM
EricR's Avatar
EricR EricR is offline
Yep, me neither, LOL.
#10-149 with a 38inch deck.
2015 Kubota BX 2670.
