Old 03-09-2012, 08:20 AM
rickv1957 rickv1957 is offline
Default Cub 149 K321A Question
Hello All,
Please check out the attached picture. Should there be another piece of tin or shroud covering the head on my 149?
thanks rick
Old 03-09-2012, 08:23 AM
Well I had said no, but I was wrong. There is another piece, altho I don't think it is absolutely needed.
Here is a pic of my 128 motor with all the tins in place.
Without the head tin installed:
Old 03-09-2012, 08:27 AM
149 - 498944's Avatar
149 - 498944 149 - 498944 is offline
Yes. You're missing a piece between your top plate and your fan shroud. It wraps over each side of your head and attaches with small screws to the head itself. you should be able to see the screw holes there.
If you look close at this pick you can see what your missing.
Cub Cadet 149 (Restoration Completed 2012)
Cub Cadet 149
Cub Cadet 127
Front Blade
1A Tiller
38" Mower Deck
44" Mower Deck
48" Scraper Blade
Plow
spare 12 HP Kohler
Old 03-09-2012, 06:12 PM
Yes, that other piece of tinwork needs to be there to direct the air over the cooling fins.
If it wasn't needed, the factory wouldn't have included it...
Old 03-10-2012, 05:56 AM
Vince_o Vince_o is offline
Im with Matt, with out it the air from the fly wheel wont move across the head and cool it.
Old 03-11-2012, 07:19 AM
Thanks for the replys. It looked like there was a link missing in the chain. Will start looking for one.
