Old 03-12-2012, 02:25 PM
KayakDon's Avatar
KayakDon KayakDon is offline
Default PTO pulley
Hi, I have a 2182 and I was wondering if it is possible to replace just the pulley on my PTO. I have not removed it yet, just working from the computer looking for parts first. I dont see any replacement numbers at any of the Cub parts web sites. Anyone have a part number, or maybe its not possible to replace just the pulley. Thanks, Don
Old 03-12-2012, 06:02 PM
Don
I have a clutch off my 2182 thats pretty well used up but the pulley is OK. Pretty sure the bearing could be replaced. If you need to replace the complete PTO let me know and I'll dig up the part # for you and the place I got mine from.
Sam
Old 03-12-2012, 07:04 PM
KayakDon's Avatar
Thanks for the quick reply Sam. My PTO works just fine, but I think I have a pulley that is the wrong size! My pulley is 4" in diameter and I think it is supposed to be 6". I would like to just replace the pulley with the right size without the cost of a new PTO. Is it possible to replace just the pulley?
I dont see just the pulley listed for sale anywhere. Thanks, Don
Old 03-12-2012, 08:06 PM
Frank1541 Frank1541 is offline
Here is the number. 759-3646. It is listed as the armature not the pulley. Just go to parts tree and look under the 1862. The early version has the small pulley the later version has the larger pulley.
Old 03-12-2012, 08:19 PM
At serial #821,060 and above (1992 and newer) they changed from a 4.6" pulley to a 6" pulley. If yours is built before that it may be correct. Here is mine when I took it apart to put new bearings in it.
Old 03-12-2012, 09:11 PM
Don
My 2172 has the 6" pulley I got the new one from Pat's small engine plus
http://www.psep.biz/store/cub_cadet_...pto_clutch.htm
Reason I changed it is the bearings were on the way out and the field coil insulation was pretty well toast.
Old 03-12-2012, 09:27 PM
KayakDon's Avatar
My 2182 is #808XXX so it is early. So maybe the 4 1/2" pulley is correct. I was thinking this was not the right size cuz that would explain the poor performance of my 451 snowblower. Would it be better to have the 6" PTO pulley for the better rpm 's?
Old 03-12-2012, 10:09 PM
Don
Sorry I can't help you on this one. I've never used a Cub snow blower. You may want to check with Matt G or Roland if they don't know I'm sure they can ponit you in the right direction.
Old 03-13-2012, 12:36 AM
EricR's Avatar
EricR EricR is offline
Don, you need the 6 inch pulley for a 451 snow blower, as my Dad's 2084 has that set up and we just changed the front bearing and his is the 6 incher.
And his 451 blower will throw, LOL.
#10-149 with a 38inch deck.
2015 Kubota BX 2670.
Old 03-13-2012, 08:59 AM
KayakDon's Avatar
Thanks for all of the info. After spending all winter trying to figure out why my blower was so wimpy, it turns out that I have an early 2182 with the 4.5" pulley. So.. the early (4.5" pulley) 2182s need the 450 blower, and later (6" pulley) 2182s need the 451 blower. We have discovered the info I've been looking for!! Thanks for all of the HELP!! KayakDon
