Old 03-18-2012, 06:54 AM
BIGMOZEKE's Avatar
BIGMOZEKE BIGMOZEKE is offline
Default 1806 Wiring Diagram
Putting a magnum in my 982 from an 1806, does anyone have a wiring diagram for this?
Joe
Old 03-18-2012, 07:25 AM
This would definitely be a "Custom" drawn diagram. I'll see what I can do later today.
Old 03-18-2012, 07:36 AM
BIGMOZEKE's Avatar
Thank you very much Roland.
FYI...there is no wiring harness in the 982 and I have the harness out
of the1806, I just need to know where to hook up the terminals.
Sorry that I wasn't clear. Both seem to be very similar.
Old 03-18-2012, 09:11 AM
OK....need add'l information.
a) What is the Chassis Serial Number of your 982?
b) What options does your 982 have (ie: rear PTO)?
Old 03-18-2012, 09:22 AM
BIGMOZEKE's Avatar
Chassis serial number 2050592U674662
No rear PTO no other options other than the dual hydraulics.
Joe
Old 03-18-2012, 09:57 AM
GREAT... you have a IH built tractor.
One last thing. Are you going to use the Ignition Switch from the 1806 or the 982..???
Old 03-18-2012, 12:01 PM
BIGMOZEKE's Avatar
Will use the 1806 switch
Old 03-20-2012, 02:07 PM
BIGMOZEKE's Avatar
Bumped to remove post
Old 03-20-2012, 02:40 PM
If you can be patient, I can do this for you. If you are in a hurry, then maybe some one else can jump on it.
Old 03-20-2012, 02:54 PM
maddog784's Avatar
Sounds to me like a wiring diagram from a 782 is what you're looking for. Safety options were all the same, and that's basically what you're making. Trust me - I just put an 18 Mag in my 982 and used my 784 for a basis. Right, wrong, or indifferent, it runs. I guess that the later model 18 Mags have the oil pressure sensor - that might throw a wrench in.
CCC 784 w/ Triple Hydraulics
IH 982
50C Deck
41" IH Rear Blade
QA42A Snowthrower
