Old 03-18-2012, 11:08 AM
brentwd's Avatar
brentwd brentwd is offline
Default Grass deflector for 44 or 50 decks
I was looking for pics and measurement for the grass deflector shield for the WF thru 82 series. It bolts to the discharge side of the deck. Thanks in advance.
Old 03-19-2012, 11:06 PM
maddog784's Avatar
Are you talking about the rock deflector that mounts underneath the deck with 2 bolts? I have one, I can get some measurements tomorrow.
CCC 784 w/ Triple Hydraulics
IH 982
50C Deck
41" IH Rear Blade
QA42A Snowthrower
Old 03-19-2012, 11:32 PM
4SPEED's Avatar
4SPEED 4SPEED is offline
I have one for my 582 . it bolts to the discharge on the deck. kinda like the plastic junk deflector shields on todays mowers, only this one is metal. I'll get pics for yah tomorrow.
Doug
Original , 100 , 125 , 582
Old 03-20-2012, 09:16 AM
brentwd's Avatar
Maddog 784, I believe that is it. Also is it called a rock deflector than a grass deflector? Thanks for the reply's guys
Old 03-20-2012, 10:13 AM
maddog784's Avatar
I can't be sure, but I think the purpose of it was to knock down rocks. Knocks down grass in the process, also. Parts lookup just calls it a deflector, so sounds like you're right.
Why do you ask - are you wanting to make one? If so, I have one that I'm not using.
IH 982
50C Deck
41" IH Rear Blade
QA42A Snowthrower
Old 03-20-2012, 12:56 PM
PaulS's Avatar
PaulS PaulS is offline
There should be a ton of those around as it is usually the first part to be removed from a mower and placed at the very back of the shed or garage. I use a DR lawn vac and had to remove that piece to mount the boot.
Old 03-20-2012, 07:51 PM
Regardless of what it was meant to do, what it actually does is make nice windrows. Not very nice unless you bale your grass clippings.
Old 03-20-2012, 08:07 PM
But makes it nice for a yard sweeper.
Old 03-20-2012, 09:27 PM
brentwd's Avatar
I would just like to make them so I will have them for the future. I need the 44 and the 50. Thanks guys
Old 03-20-2012, 09:53 PM
4SPEED's Avatar
save the pics , my photobucket is kinda full. so I'll delete them in a few days
Doug
