Guys,
I was mowing this weekend.. it seems like there is a lot of movement during engagement of the mower deck on the pulley. I can hear a constant loud rattling noise from the pulley lock( when you pull it fwd to replace a belt). Is this normal? I assume that the only real problems would be a bad pulley bearing or the spring. Correct? Michael |
Ok,
I'll check the pulleys. SPring does not look broken? Do they get weak with age? |
I have heard rattling on mine, but I think it was just the locking lever rattling vertically. It's not overpowering sound, but just sounds like chain rattling in the front.
CCC 784 w/ Triple Hydraulics IH 982 Cub Cadet Commercial H1748 Walk-Behind 50C Deck 42" Hydraulic Angle Front Blade 41" IH Rear Blade QA42A Snowthrower |
Sounds like it's normal to have the rattle.
I'll check the bearings.. and put a new spring on it with the new belt this spring. Michael |
Never hurts to give the whole thing a "once-over" before mowing season hits hot and heavy.
thanks guys...
I put a new belt on it and replaced the pulleys(only 1 was bad). It's much better. The rattles are the metal spring is almost gone. I threw it out and put a oring on each side instead- dead quite now. Need to work on the angle for the idler pulley on the mule drive. Lots of play on the tensioner side. Maybe a new shaft and some work to the lever arm- bushings, brazing, etc. Michael |
