Old 03-22-2012, 11:37 PM
cavmedic cavmedic is offline
Default 1450 3 point lift arm pic request
Could someone post a pic of their lift arm on a hydro lift setup? I have the install instructions printed , but they are not the clearest and I am having a difficult time imagining how the lift arm and lift arm attach plate go together.
I think it goes in the bottom two canted holes but not 100% sure .
As you can see , it is not the best diagrams
Old 03-23-2012, 07:29 AM
maddog784's Avatar
Sorry, no pics, but I will say that I think you'd be right to use the 2 bottoms holes. There should only be one other open hole and it's for a float lockout pin.
CCC 784 w/ Triple Hydraulics
IH 982
50C Deck
41" IH Rear Blade
QA42A Snowthrower
Old 03-23-2012, 07:33 AM
Ok , looking at the diagram also . Is it safe to assume everything mounts to the right side of lift arm ? Pin facing right ?
There really is not much room in there ...LOL
Old 03-23-2012, 08:26 AM
maddog784's Avatar
Yes - the lift bar should be up against the frame. Does that little plate have threaded holes in it or do you have to put a nut on it? I had a 128 with a lift on it, but I don't recall.
IH 982
50C Deck
41" IH Rear Blade
QA42A Snowthrower
Old 03-23-2012, 08:29 AM
The mounting plate has threaded holes for the mounting bolts.
