Old 03-23-2012, 07:13 AM
hanoverheel hanoverheel is offline
Default Spiral Spring Pin
Last night I broke the pin that connects the drive shaft to the back of the engine on my 1812 and I just want to make sure I am getting the correct part to replace it. I think the correct number is 915-3000. Can anyone confirm this is correct?
Is it possible to drive the old one out and put in the new one in without removing the engine from the tractor? Any tips or tricks would be appreciated.
Thanks for the help.
Old 03-23-2012, 08:58 AM
After looking at parts look up that is the correct part number. If your going to try and replace it while it's in the tractor support the drive shaft upand you should be fine. You should be able to use the new to knock out the old spirol pin.
http://www.cubcadet.com/webapp/wcs/s...A/040029900008
Old 03-23-2012, 09:44 AM
tex599 tex599 is offline
Just removed these from my drive shaft. Soak in wd-40 and use a punch, they just come right out.
