Old 03-24-2012, 09:53 PM
CubDieselFan's Avatar
Default Bringing a 1810 back to life
I have a 1810 that I bought from my brother in law. He was storing it at his house and now he wants it moved. The hour meter shows 408 hours and it will not start, it will run if I pour a little fuel in the carb. It has the Warbro carb on it. It runs real good when it is running, no smoke. I know the carb set up is wrong because when it does run it is like it runs away, the throttle is set to half and it runs way past half. With that amount of hours do you think the a rebuilding is going to help or is a change to a Kohler carb in order? Thanks for the help.
Old 03-24-2012, 11:07 PM
TheIHMan's Avatar
TheIHMan TheIHMan is offline
I would just buy a Kohler carb for it.
Old 03-24-2012, 11:24 PM
Yep, get a good carb for it.
Old 03-25-2012, 11:57 AM
weaverama weaverama is offline
Replacing the carb is a pretty drastic first step. Why not clean out the Walbro and see if that fixes it. If not, move on to the fuel pump which is expensive enough to replace.
Cub 108
Cub 1650
Cub 1000
Cub 682
Super Cub 2072
Old 03-25-2012, 12:31 PM
If it runs away, it's not the carb, it's the governor. Make sure that's set according to the service manual before you do anything else.
408 hours is nothing if the engine has been well-maintained.
Old 03-25-2012, 09:06 PM
My brother in law had it at my place about 3 years ago and when it was running you could smell gas. It has had a rough life but I know the previous owners and the person who bought it new let it set out. The next owner tried his best to fix and that is where my brother in law got it. The original owner had it on a truck taking it to the scrap yard and the owner previous to my BIL, got it for 50 dollars.
I know after my brother in law got it, someone he knows worked on the carb because everything is clean around it. I guess the cheapest thing to do is to buy a kit for the carb and see if anything was put back wrong and then clean the whole fuel system and go from there. It will be a couple of weeks before I can work on it, this is my OT week, so it is a 70 hour week ahead of me.
Old 03-26-2012, 11:19 PM
elbertjolley elbertjolley is offline
My 1810 has 1110 Hours on it and was dumped off a trailer at 55 MPH done a couple barrle rolls and still is running like a champ after carb rebuild, and rewire. I have gotten all the sheet metal for it except one engine side cover and the alum. hood hinge peice and the will be repainting. i also mower grass with it last week. i have no clue how many acres but it takes 2 fuel takes of gas
Old 03-27-2012, 02:53 AM
inspectorudy's Avatar
Default Running away
I have had small engines run away after they heat up when they are set real lean. You could try opening the jet up one turn to see if that helps, if it has a jet adjustment screw. If not then it probably is the gov.
1811 Hydro
Old 03-27-2012, 09:23 AM
If it were mine, first thing I'd do is take the carb apart and see what
you have/looks like, then decide if you need a "kit" or another carb.
Also look to see if many fingers spoiled the pie.
Most times it just needs a bowel cleaned and the passages blown out.
And by all means clean the fuel tank, as sitting outside they get lots of water inside.
and like Matt says, make sure the Gov. linkage is set properly.
Luck!
Old 03-27-2012, 11:03 PM
It will be a stretch but, I'll give you $50 like it is. LOL just kidding man. i would clean the carb really good and kit it regaurdless but, i feel that Matt is correct on this, like always go MATTT!!! He's my cub hero i wanna be like Matt when I grow up
