Old 03-26-2012, 09:15 PM
sandreassi's Avatar
sandreassi sandreassi is offline
Default Lights not working
The lights on my 782 stopped working this weekend. Any thoughts on where I should start trouble shooting? I pulled one out and tested it. The lamps are okay. They just don't come on when I have the key in the correct position.
Old 03-26-2012, 09:27 PM
cubguy's Avatar
cubguy cubguy is offline
If you have a test light try testing the "hot" wire that leads to the lamp. If its a no show you either have a bad switch or bad connections. Just my two sense. Good luck
Nroakes
Cub Cadet 3206
Allis chalmers B112
One big Green tractor
Old 03-26-2012, 09:39 PM
dieseldan123's Avatar
Maybe a blown fuse?
1967 IH Cub Cadet 123
1978 IH Cub Cadet 1650
19?? IH Cub Cadet 682
Old 03-27-2012, 06:02 AM
Power goes through the Key Ignition Switch, out on the "L" terminal to a 10A Fuse and then on to the lights.
Could be the Key Switch, fuse, or some sort of wiring issue.
See Technical Library for the wiring diagram.
