Old 03-27-2012, 09:46 AM
dbuck dbuck is offline
Default K301 dipstick ?
I have a CC127 (scrap yard save) that I have had to do alot of work on just to get to the starting part. My question is, when starting the K301, it is blowing the dipstick part of the way out of the tube. Does anyone have and ideas/suggestions on what maybe causing this? Any help will greatly appreciated and Thank you for your time.
Old 03-27-2012, 05:45 PM
ljones's Avatar
ljones ljones is offline
The rubber seal on the dipstick could be worn out, or the engine has a lot of blow by.
Old 03-27-2012, 06:31 PM
David a Calkins David a Calkins is offline
Default k-301 dip stick
take your breather apart it may be pluged ,or the reed plate may be broke,besure you mark all the parts as they come out ,,there is a very small hole in the plate next to the block ,that goes to the bottom ,
Old 03-27-2012, 06:59 PM
cubby102's Avatar
cubby102 cubby102 is offline
my k241 does that same thing and after a time of running and a little pressure (as in mowing) you can see the blowby coming out of the breather
Old 03-28-2012, 11:47 AM
Thank you guys for your replies. I though, when I rebuilt the carb. that I pulled the breather ass'y and replace the filter, but maybe not. I will pull it again and check it. The rubber gasket does not fit very tight in the tube, it is actually pushing the dipstick up thru the rubber gasket. I barrowed a leak down tester and going to run the test is PM. Thank you again for the replies. Don B.
