Old 03-28-2012, 10:18 AM
charlie105's Avatar
charlie105 charlie105 is offline
Default synthetic 10w-30/ SAE 30 year round ?
OK; I'm not trying to re-open the synthetic vs petroleum debate. We "inherited" our 105 ,and it came with 10w30 mobile 1.
I am going to switch to [ Amsoil 10w-30/SAE30 commercial grade Small Engine Oil] because :
1) It's cold here in the winter,
2) I only want 1 year round oil for the generator tractor,& lawn mower.
3) It seems to meet/exceed all CC and kohler requirements,gas or diesel. & 4) I just like synthetics.
I'll keep you posted.
Good luck to all of us.
Steve
Old 03-28-2012, 10:49 AM
Kris Brown's Avatar
Kris Brown Kris Brown is offline
Well, you wouldn't want to run 30 weight in the winter because it's too thick. I have a 680 with a K301 and I run Pennzoil 10w40 in it year round.
Kris
63 CC Original w/ 38” deck and front plow
72 129 50” deck, 42” blade
73 86 42” deck, 42” blade
84 CC 680 w/50” deck and 42" plow
89 CC 1811 46GT" deck,QA42A, 38" IH 1A tiller, Brinley-Hardy plow x2
1982 Gilson Lawn Tractor with 38" deck
Old 03-28-2012, 06:55 PM
You will probably have to deal with increased oil consumption during the warmer months if you do that.
Old 03-29-2012, 12:34 AM
ihnick's Avatar
ihnick ihnick is offline
Me and my Dad run Amsoil in everything because he is a dealer. It is amazing oil and we swear by it... except in Cubs. I ran Amsoil in a couple of them and they started to use a little oil and one started knocking. I think the oil is just so clean and slippery that its almost too perfect for those old engines. I kinda don't make sense I just realized. haha
Nick.
Old 03-29-2012, 07:57 AM
TSWolf's Avatar
TSWolf TSWolf is offline
I work for a Cub dealer, and we use SAE 30 in the K-series Kohlers, year-round, as it is what Kohler recommends.
Tyler
There are two types of people in this world: those who own cubs and those who wish they did.
I Own:
-1961 Cub Cadet Original
-1972 109
-many other non-cub cadets
Only 18, and already have multiple buildings full of equipment
Old 03-29-2012, 08:08 AM
They do NOT recommend running 30W when the temperature is below 30F; 10W-30 is supposed to be used below 30F. Check any Kohler service or owner's manual...
Cold starts with thick oil are extremely hard on an engine.
Old 03-29-2012, 08:26 AM
Merk Merk is offline
by TSWolf
You better double check the Kohler service manual.......Page 1.4 of a Kohler Service manual wants the owner to use 30 weight oil above 32 degrees, between 0 to 30 degrees use 10W-30 and if you see temps below 0 degrees use 5W-20 or 5W-30.
I've tried synthetic oil in the past. Every engine I tried it in leak oil. I didn't see enough improvement to justify the added cost.
Last summer I replaced the rear differental in my Suburban with an Eaton diff.......Eaton instructions said not to use synthetic oil with their diff.
Some think synthetic is the best thing since slice cheese.....In my book it's garbage.
Old 03-29-2012, 08:46 AM
4SPEED's Avatar
4SPEED 4SPEED is offline
I'd never use a synthetic oil. like Merk said it's garbage. there not designed for synthetic.
Doug
Original , 100 , 125 , 582
