Old 03-28-2012, 04:35 PM
Love my Super 1872 Love my Super 1872 is offline
Default Starter wont turn over on my Super 1872
Gents,
I am continually having issues where the starter won't turn over. All I get is a click when I go to start it. The lights work and the fuse is still good. It has a brand new 370cc battery. Are there a few things I can check before rebuilding the starter?
Old 03-28-2012, 05:46 PM
PaulS's Avatar
PaulS PaulS is offline
Check your wire connections especially the pos battery connection. Check all your connections to make sure you have good connections.
Old 03-28-2012, 05:48 PM
I would first check to make sure the solenoid hasn't failed. That's far more common than the starter ceasing to function all of the sudden.
Old 03-28-2012, 07:40 PM
PaulS's Avatar
Old 03-29-2012, 09:25 PM
Iowa Farmboy Iowa Farmboy is offline
It might not hurt to take out the plugs and make sure the fuel pump didn't fail. Cause when it fails they can fill the crankcase up with fuel, making the motor hydro locked. I had that happen to me and the first thing I was thinking was the starter too.
Josh
1989 SGT 2072 (restored)
60"Haban Deck, 54 "Haban Blade, 48" Cub Cadet Tiller, 12" Brinly Cat O plow, 48" Cat O landscape rake
Cub 128 with creeper and rear PTO with reverser(next project)
IH built 682 and 782 that will combine to make one
