Old 03-23-2009, 11:02 PM
mjd's Avatar
mjd mjd is offline
Default Better fastener idea for tunnel cover?
Hey all,
Love the new site!
I just found a replacement frame cover with all the paint and graphic intact. My old tunnel cover had gotten rusty with the paint chewed up around the four bolt holes from years of taking them off and on.
I am wondering if there is a better approach than plain cap screws? Maybe some washers under the cap screws so that they don't dig through the paint or maybe a nylon cap screw or perhaps no screw or bolt at all -- but some kind of fastener that is tool-less?
I plan on keeping my 1862 for a long time and don't know whn the next pretty and cheap frame cover is going to come along.
Mike
Old 03-23-2009, 11:16 PM
Merk Merk is offline
I use an allen head stainless steel bolt, flat washer and a lock washer in my Wide frame Cubs tunnel cover.
Old 03-24-2009, 12:59 AM
murphycc
Guest
Posts: n/a
+1
Since some holes are stripped I just go ahead and tap them out with 1/4" tap, don't even need to drill the hole out.
Scott
Old 03-24-2009, 09:01 PM
mjd's Avatar
mjd mjd is offline
Thank you both for the suggestion. I picked up some SS allen head bolts and washers. Looks like The frame holes have to be enlarged for a 1/4" bolt to go in.
I have a tap around here somewhere....
Mike
Old 04-04-2009, 09:50 PM
rfrank's Avatar
rfrank rfrank is offline
On my 149 I ran a 1/4 20 tap thru them, almost as if the holes were clearanced fit to be tapped. and used stainless hexheads. Looks good and wont rust. 7/16 socket and they are easy on and off.
Old 02-04-2010, 05:38 PM
midyearguru midyearguru is offline
...........I have a broken 1/4-20 tap stuck in one of the holes! That'll teach me to try and do it fast. Now, off to find the EZ outs!
Old 02-04-2010, 11:11 PM
murphycc
Guest
Posts: n/a
You cant e-z out a tap, but you can shatter a tap with a punch. If you can't reach part of it with pliers and twist it out you'll need to us a punch and force it out.
Scott
Old 02-06-2010, 09:53 PM
placeebo effect placeebo effect is offline
maybe somthing on this page would work
http://www.smallparts.com/s?searchNo...&Action=submit
they are poly drive rivits
or even use the poly screws they have
Scott Larson
Climax,MN
Its not cold. its gods way of keeping the rif-raf out.
Old 02-07-2010, 03:09 AM
I'm not sure why you'd want to use drive rivets if you ever want to be able to remove the tunnel cover easily again. Plastic screws will last about one insertion/removal cycle....
Old 02-07-2010, 09:57 AM
the screws and rivits are made for that matt. thats why they sell them in bulk for cheap. when used on other apps you can dis assemble everything quickly. plus nylon won't mar the paint
Scott Larson
Climax,MN
