Old 04-03-2012, 01:49 PM
nikster's Avatar
nikster nikster is offline
Default Battery drain?
Just started Sat.
Started up my # 122 ran fine:
Sunday start up & no power to start.
Figure I left the key on?
Put the charger on & less than 1 minute, starts right up.
Let it sit overnight & dead again this morning.
It's a good battery, but sitting overnight there is not enough power to start it.
What does one do to narrow down the search for a battery drain?
Thanks,
Nik.
Old 04-03-2012, 03:29 PM
TheIHMan's Avatar
TheIHMan TheIHMan is offline
My guess is a bad S/G. A bad one will suck the juice out of a new battery in no time. I had that happen on an ole Farmall B just after I put a new battery in it.
Old 04-03-2012, 05:13 PM
Pull off the positive cable from the battery overnight.
If it still will not start the next day, it ain't the tractors fault!!
Old 04-03-2012, 07:43 PM
jbrewer's Avatar
jbrewer jbrewer is offline
That's a good first start!
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 04-03-2012, 07:58 PM
David a Calkins David a Calkins is offline
Default battery drain
it may not be the battery ,with only a min to charge ,it may be the c/r spring ,it may be weak or broke ,,pull the spark plug ,and test compression ,if its high ,the spring is bad ,keeping the exhaust closed ,making it hard to start .hope this helps .David
Old 04-03-2012, 09:39 PM
Check to see if the cutout part of the voltage reg is opening when you shut it off or you will be discharging through the S/G
Old 04-03-2012, 10:13 PM
nikster's Avatar
Done we'll see what happens?
Nik,
Old 04-04-2012, 09:13 AM
nikster's Avatar
I disconnected the battery, hooked it up this morning & lots of power & started right up.
WHAT does S/G stand for?
Nik,
How does one check out a voltage regulator ??? To find out if a lead is open?
Old 04-04-2012, 10:06 AM
Nik, S/G is the Starter/Generator.
Old 04-04-2012, 12:58 PM
Now you disconnect the positive cable from the battery, then connect a 12 volt bulb between the cable and the battery post.
The bulb will light up.
Start disconnecting things until the bulb goes out.
When the bulb goes out, you have found the component that needs fixed/replaced.
