Old 04-03-2012, 08:00 PM
Cub 128 Cub 128 is offline
Default Cub Cadet 128 project
So, I picked this Cub Cadet 128 up off of a guy on Craigslist for $150.
Came with two sets of turf tires on wheels, a single ag tire on wheel, Hydro transaxle (going to get a 3 speed), home made drive shaft, and a K301 that is on stock bore and stroke, but doesn't seem to be from a cub as there is no drive hub, and the starter connects with a belt to the flywheel.
Ive got some pics to post up and some questions coming soon...
Old 04-03-2012, 08:27 PM
Default pictures
Front part of the hydro bolts in the lower hole.
Can anyone I.D. this hydro
Front pulley on the pto side, guessing this isn't supposed to be here?
mounts for the hydro
serial number
Old 04-03-2012, 08:57 PM
If the tins on the motor are OEM, it is a 12hp engine made in 1967. Can't help with much else on the motor.
Old 04-03-2012, 09:06 PM
ok, cool thanks, so do I need to buy a pto clutch for the pto side? im not going to put any attachments on it, its going to be for stock class pulling.
So anybody know where I can get a cheap drive hub and drive shaft/clutch setup for a 128?
Old 04-03-2012, 09:08 PM
If your going to pull it, you won't need a PTO.
Place a want add in our Wanted section and or also give our Sponsors listed at the top of each page a call with your needs.
Old 04-03-2012, 09:29 PM
ok, Thanks
Old 04-03-2012, 09:42 PM
I measured my bore and it is at 3.376" or 85.7504 mm, and I was going to get a new piston and rod but they don't look bad at all there was barely any carbon build up? but I do want to replace the rings just for good measures.
So can I just use a balled flex hone to get some cross hatches on the wall, or should I spend the extra money and get a new piston and bore it .010 over?
Old 04-03-2012, 09:49 PM
tires and wheels I got with it
Its resting place
pulley for the starter.
Old 06-23-2014, 11:56 PM
moparman849 moparman849 is offline
First off the k301 is the best 12 horse you can buy because you can bore a lot off the cylinder walls
Old 06-24-2014, 09:30 AM
dbuck dbuck is offline
Smile
Should not a 128 be gear driven to start with? Also why is the starter pulley on the flywheel side?
Don B, USAF 1962-1968, Ft. Wayne, IN
