Old 04-04-2012, 11:27 AM
tex599 tex599 is offline
Default Driveline Clutch, compress spring
Need some ideas on how to compress clutch spring to put the roll pin in. I know they make a special tool for this, but i do not have it. Any ideas? Thanks
Old 04-04-2012, 11:55 AM
On your 1050 you could do it as they show in the 70/100 manual pages 17 and 18.
http://www.onlycubcadets.net/forum/s...ead.php?t=4640
Old 04-04-2012, 01:10 PM
I stick the 5/8" shaft in a vise and clamp slightly. the spring is resting against the vise.
Tap the shaft end with a soft face hammer.
When the spring is compressed enough, tighten the vise, and install the pin.
When you realize the hole is not properly oriented to allow you to get the pin in, slowly release the vise, realign and start over!!
Old 04-04-2012, 01:40 PM
PaulS's Avatar
PaulS PaulS is offline
A couple weeks ago my son and I rebuilt a clutch on an original and had to replace the spirol pin that is at the end of the long spring. We used a vise while my son braced the engine end of the shaft in front of his hip and grabbed the vise and compressed the spring I tightened the vise and changed the pin then slowly let the vise loose and viola pin changed. It pays to have a rather strong person do this and pad the end of the shaft but it worked for us without having to find someone with a press.
Old 04-04-2012, 05:44 PM
I use this.
Old 04-04-2012, 07:39 PM
Matt
That looks like it would make it an easy job. Nice design work.
Old 04-05-2012, 11:22 AM
Thanks, ended up using a press with an oxygen sensor socket, worked great.
