Old 04-06-2012, 01:02 PM
steveyrock's Avatar
steveyrock steveyrock is offline
Default K301 balance gears
I have heard balance gears can be removed with out removeing the crank.
Can someone who has done it give me some insite before I start disassembly on a good running engine.
Don't really want to disturb this engine as it has no issues other than I want rid of them gears.
122-snow blade and 42 deck, wheel weights, fluid filled tires,chains
106-42"deck
1250-44 and 50" decks
147-44"deck
2155-42"snowblower 38"deck, chains,suitcase weights
Exmark Quest-zero turn 42"deck 23hp Kawasaki engine
Old 04-06-2012, 01:32 PM
wshytle wshytle is offline
Default Removal of grenade gears
Open the bottom of the engine. With snap ring pliers remove the snap ring on the gear closest to you and slide it off of its post along with all of the shims and spacers. You'll need a flashlight for the second gear. The gear has webbing and you want to have the webbing facing you. With a long punch just crumble the gear webbing using the punch (cold chisel) and a hammer. It doesn't need to be completely crumbled or broken up. Be careful and pay attention to any fragments. I use a magnet here and sweep the crankcase well. After the gear crumbles it can be moved around and then removed from its post as well as all of its shims and spacers. BTW, you'll need a right angle snap ring plier here to remove the ring. You have to hold your mouth just right but it will come off. Make sure the pliers fit the snap ring gripping holes well. It just makes it easier.
You should end up with one complete gear and one broken gear. You might also notice some missing needle bearings so keep an eye out for them while cleaning the engine case.
After cleaning the engine of any fragments just slap the oil pan back on (hopefully the gasket was salvaged) and you're good to go.
Old 04-06-2012, 02:26 PM
steveyrock's Avatar
Many thanks wshytle.
I got all the tools and a new gasket now if I can find my telescopeing magnet.lol
106-42"deck
147-44"deck
Old 04-06-2012, 06:32 PM
Vince_o Vince_o is offline
12's can be removed in the engs, Ive done many of them. The 14's the crank has to come out, Ive tried many of them.
