Old 04-08-2012, 12:40 AM
oldhippie oldhippie is offline
Default new owner in central Wisconsin
I just got what I was told is a model
71 Cub Cadet.
don't know a lot about it other than it is yellow and white
but it seems to run ok
so far only things that I have done are oil change,new air filter and spark plug.
seems to me that the brakes could use some adjusting but first were are the brakes I do not see anything on any of the wheel hubs that look like they would be brakes
Old 04-08-2012, 07:52 AM
ToddW's Avatar
ToddW ToddW is offline
Welcome Oldhippie! I'm from Appleton. That is one sweet looking loader and cub! Looks like someone had extra stickers from a Farmall Cub and put those on your hood.
Where in heck did you find this cub set up? Congrats!
Cub Cadet 108, IH snowthrower, IH ?? mower deck
Cub Cadet 1650, IH 44 mower deck, IH snowthrower
1960 Cub LoBoy- yellow roundnose. Fast hitch w creeper and roto tiller, front blade, mower deck and Fast hitch one bottom plow and rock rake
1951 F Cub with Wagner loader and woods brush hog, 152 disk plow and 23A harrow
1953 Ford Jubilee tractor and F100 Pickup
Old 04-08-2012, 07:59 AM
4SPEED's Avatar
4SPEED 4SPEED is offline
the brake is internal. the lever with the adjustable bolt is the brake. is seen in your last pic.
lower front is the brake lever
disc
disc puck
buy the way ,,, sweet cub. love the loader
Doug
Original , 100 , 125 , 582
Old 04-08-2012, 08:37 AM
Nice loader!
Old 04-08-2012, 09:25 AM
I found it on craigslist,someone by Wisconsin Rapids had it.
any way to find out about when it was made? anything
available as far as shop manuels?
also it is going to need new front tires would like
to put a pair of these on the front
http://www.millertire.com/products/l...e-3-rib-front/
but I noticed that those tires are only rated for 435 lbs
so with the loader would that be to much for those tires?
I will have to look under the tractor and see if I can find
that lever and if there is anything to adjust for brakes
Old 04-08-2012, 10:45 AM
If I were you, I'd stick with the smooth front tires if you're planning to use it...it will get even harder to steer if you put tri-ribs on it. The optional wider front tires would probably help some, too.
Old 04-08-2012, 11:49 AM
Looks like you've got a moded kwik-way loader. I love loaders!
Manuals can be found in the tech section of the site.
Chassis
http://www.onlycubcadets.net/forum/s...ead.php?t=4641
Operators
http://www.onlycubcadets.net/forum/s...ead.php?t=4662
Our great site sponser Binder Books has hard copies of all the manuals. Click on their banner at the top of every page.
Welcome to the addiction!
Old 04-08-2012, 12:08 PM
Glad to have you! Nice 71 and loader.
Old 04-08-2012, 01:42 PM
thanks very much,those manuals will be very helpfull.
I need to fix were the bucket pivots on the loader arms
all that there is is a bolt through each side of the bucket
and it tendes to bind a bit
to me that does not seem to be a factory set up
also need to find or make something for rear wheel
weights,pick up something with the loader and back of
tractor wants to lift
would also like to find or make a back blade
Chassis
Operators
Old 04-08-2012, 02:11 PM
Your welcome! This is what I did for my son's 125 with Kwik-Way loader. Incase you want to know there's 818 lbs with me in the seat and it still seems light in the rear.
