Old 04-11-2012, 07:27 PM
gtsind gtsind is offline
Exclamation Kohler M18 need new carb ?'s
Hi Folks,
782 80ish? with Kohler M18.
It looks as though I will need to replace my Walbro Carb. Water damage and clogged, w/ pin hole in bowl.
Any suggestions on where to go for purchase or rebuild?
Any info is greatly appreciated.
Best Regards
Gary S. in Tampa Fl
Old 04-11-2012, 07:33 PM
4SPEED's Avatar
4SPEED 4SPEED is offline
I may have 1 or 2 of them. Im sure they need a kit , but in working order. Im not sure what there worth or what to ask for it.
Doug
Original , 100 , 125 , 582
Old 04-11-2012, 07:47 PM
Hi 4speed,
Thanks for the quick response. Do you know of an upgrade or step up?
Other various things I've read that possibly from a larger motor it may run better?
Also I found a place in MO that will rebuild mine? Not sure about that.
I was hoping to maybe find a new one if it exists.
I'm working on this machines 2nd life and hoping to make quality choices.
Thanks so much for your input.
Best Regards
Gary S in Tampa Fl
Old 04-11-2012, 08:30 PM
cubpsycho cubpsycho is offline
Default 782
Hi Gary,
I can't speak for your 782, but rebuilt mine in my 982, 2 or three times, and found new one on ebay. There not cheap, but worth every penny, just stay away from the garbage 87 octane, hope this helps.
John
Old 04-11-2012, 09:50 PM
4SPEED's Avatar
Originally Posted by gtsind View Post
Hi 4speed,
Best Regards
Gary S in Tampa Fl
I have no clue, there maybe some other guys here that know more about them.
and x2 never use the 87 octane. our engines & carbs dont like the ethanol in it so you need the high grade gas.
Doug
Old 04-12-2012, 05:59 AM
You can use a Kohler adjustable Carb from a KT-17 just fine.
Old 04-12-2012, 06:02 AM
Vince_o Vince_o is offline
Like Rolland said, Im running 2 carter #26 on mine
Old 04-12-2012, 05:56 PM
Default Headed for shop rebuild for the carb.
Gentleman,
Thanks for all the input.
Two local shops gave same response I've been hearing. Shop rebuild if you can find one. I will give it a try, and update in a week or so.
I may need to check back on what 4speed has if this doesn't work.
Thanks again.
Gary tpa fl
