Old 04-14-2012, 08:42 AM
CubNub's Avatar
CubNub CubNub is offline
Default Plow question
A guy is selling a plow but doesnt know if its a narrow frame or wide. He said the measurements of the frame are 10 1/4". Does anyone know if this is a narrow or wide frame plow?
Old 04-14-2012, 09:57 AM
4SPEED's Avatar
4SPEED 4SPEED is offline
it will fit both. all you need to know is if it a sleeve hitch or 3 point.
Doug
Original , 100 , 125 , 582
Old 04-14-2012, 10:15 AM
Sugarmaker's Avatar
CubNub,
Sorry I have to ask, is this a front blade snow type plow or a moldboard garden plow? If a front plow then: If the forks coming back under the tractor are same width it would be for a NF. If the forks narrow as they come under the tractor it is for a WF. If it's a moldboard it should fit both as Doug mentioned.
Again pictures would be great.
Regards,
Chris
Casbohm Maple and Honey
www.mapleandhoney.com
Old 04-14-2012, 10:33 AM
CubNub's Avatar
Its a front snow plow. I dont know why I didnt do this to begin with but heres some pics.
File Type: jpg 5F65J25M73na3Ka3Jcc4cbed656d93a5612b9.jpg (37.5 KB, 136 views)
File Type: jpg 5F95M65J33Me3I53Ncc4c5c0a408e07c815da.jpg (34.9 KB, 136 views)
Old 04-14-2012, 11:20 AM
Sugarmaker's Avatar
Yea that helps!
I would say you have a nice narrow frame blade there. Do you own it yet? Looks like it will clean up real nice. I should be out working on mine right now!
Regards,
Chris
Old 04-14-2012, 05:50 PM
4SPEED's Avatar
didnt think,,,, sorry. the front blade !!! Im just used to calling a blade a blade and a plow a plow.
Doug
Old 04-14-2012, 06:40 PM
Chris is correct. That's a NF blade. If you have a WF, the sub frame is different. You'll need a WF sub frame.
Old 04-14-2012, 07:21 PM
CubNub's Avatar
Thanks for all the help guys. Im actually driving home with it now. I picked it up from a guy in CT for $110. I have a NF so everything ended up great. Thanks again guys
Old 04-15-2012, 03:04 PM
CubNub's Avatar
Now that I have the blade does anyone have instructions or know how it goes on. I was toying with it for an hour or so and cant seem to line things up right. Does the subframe go on the inside of the frame foot pedals or the outside? When I put it to the outside it doesnt have enough clearance to click into the front of the frame. Im lost and cant seem to get it put together.
Old 04-15-2012, 04:07 PM
It goes on the outside of the frame. I think the manual is in the tech section or on the PDF site.
http://ccmanuals.info/pdf/
