Anyone ever converted a quick attach mule drive off a NF to fit on a 70/100 frame? I would like to set up my 70 for mowing but the mule I have is QA. Was also wondering if the little 7hp will spin a 42" deck???
129 Plower; 72 pile;122 daily driver, 2-42inch blades 42 inch deck- 06 GMC 1500 4wd- 1964 farmall 706 |
It would spin it, but that is too much mower for a 7hp. That's a lot of resistance when you throw in 3" of grass to cut and to move the machine.
There's no conversion necessary, it bolts on.
If you didn't let the grass get out of control, you might be able to get away with that. The 800 I briefly owned could handle a 44" deck just fine. Those 38" decks actually pull really hard, probably harder than the larger decks because of the speed those tiny outer blades must be turned to be effective. |
I run a 44a on my 86 in 2nd gear no problem. If its thick grass then I bump it down in first but otherwise it has plenty of powering
Nick. ![]() Cub cadets 100, 125, 86, 108, 109, 128, 129, 129, 149, 149, 169, 1450, 1650 and a handfull of parts tractors. #40 box blade, ih back blade, rear ih rock rake, #2 cart, windbreaker soft cabs, windbreaker hard cab, cozy cab, kwikway loader , wards corn planter, brinly plows, culitvator, rear blade, disc and the usual decks, snowblowers and 2 tillers |
You got that, right!
