Old 04-17-2012, 03:08 PM
jluster jluster is offline
Default Tiller my 129
I bought my first CC, a 129, less than a month ago and have acquired a 109 (blown engine, piston does not move), a 1650 (drive shaft was cut to get it in neutral) and a 1200 disassembled and missing the clutch/drive shaft.
I REALLY want a tiller and 4SPEED has a 2A he is willing to sell me. However, what do I need to get this on my 129? I can steal the hyrdo lift/pump of the 1650 (I assume). My mule drive runs a 44U deck on the 129. I have two other mule drives but I am not sure what deck went with them. I think one mule drive was with a 44A deck that went with the 1650 (took the 50" deck he had instead).
So I know I will need a long belt. What else anyone?
129, 109, 1200 x 2, 1650, 882, 1450
2A tiller, 50" & 44" decks
Brinly 12" plow
Brinly Disc Harrow
Snow Plow
Joe Luster
Cincinnati
Old 04-18-2012, 12:01 PM
Depends if he has the 5/8 pulley on the gear box you'll have to change that out. You'll need a new long belt and everthing else will bolt right up. Does your 129 have spring assist or hydraulic lift? I perfer hydraulic lift myself.
Old 04-18-2012, 01:05 PM
I have a hydro lift on a 1650 I will move to the 129. Have to take the pump with it, I assume it bolts right up. Looking for a spring assist but they seem pricey compared to buying a 1650 for $300, that might run (haven't had time to work on it) and getting the hydro pump and lift and all the other parts with it! I will have to check my other cubs to see if they have spring assist!
Also, just got off the phone with 4SPEED and he says it is a model 2A that was purchased with his 682 toward the end of IH's production. It is just like his model 1 tiller that he recently restored and thinks they just changed the model numbers for marketing or branding purposes.
Well I am picking up Saturday and hopefully will be tilling by end of day Saturday or Sunday!
Brinly 12" plow
Brinly Disc Harrow
Snow Plow
Joe Luster
Cincinnati
Old 04-18-2012, 03:45 PM
mmzullo mmzullo is offline
Hydro lines from the pump to lift valve are different. Also a couple pieces for the rockshaft are different.
Old 04-18-2012, 04:33 PM
Well then I better get that 1650 running! Thanks for the info!
Brinly 12" plow
Brinly Disc Harrow
Snow Plow
Joe Luster
Cincinnati
Old 04-18-2012, 05:35 PM
That sounds like a great idea!
Old 04-18-2012, 07:11 PM
Those 1650's love tillers anyway..
Old 04-20-2012, 11:20 AM
Well the 1650's engine seems locked up. The starter works when I took it off and tested it. The magnetic switch just clicked with the starter on. The drive shaft was removed and I cannot turn the engine by hand. My 1200's engine only rotates about 1/4 turn either way before I hear it hit something. Guess I need to try more before I buy.
So I committed to an 882 today! Nice diesel tractor for cheap and close by! It has hydro on the front and for the deck. I raised and lowered the deck nicely, but no lift on the rear! So knowing I have a 1650 with lift, I wonder if that will bolt on the 882. I can't see it working though because the gas tank appears to be in the way.
I am striking out on tilling this weekend! Need to sell off the 1200 and 1650 and get a lift or something for the 882. Yellow Fever has bitten me and I need to slow down.
Joe
Pictures:
IMG_20120420_081524 by Joe Luster, on Flickr
IMG_20120420_081517 by Joe Luster, on Flickr
Brinly 12" plow
Brinly Disc Harrow
Snow Plow
Joe Luster
Cincinnati
Old 04-20-2012, 11:32 AM
Nice score on the 882!
Old 04-20-2012, 11:52 AM
Joe
Joe I wouldn't trust a tiller on that Alum. rear end. Isn't the gas tank over the rear end on the 882.
Good score just not sure if it will work or if you'll have to change things up and use a plow, disc set up like DWayne aka DX3 uses.
Tags
#1a, 129, 1650
