View Poll Results: should i trade
keep the 169 and put back to original 32 82.05%
trade for original 7 17.95%
Voters: 39. You may not vote on this poll
Old 04-18-2012, 09:23 AM
cubby102's Avatar
cubby102 cubby102 is offline
Default got a trade offer, whats your opinion
as some of you have seen i posted about a 169 that i am going to get, well my boss offered to trade me his original with deck, 3 point and spring assist for the 169 that we dont know if runs, has no deck, no pto and home made foot controls for the hydro, what do you all think i should do? i figure they would both be worth right around the same, only problem with the original is it needs a blade belt and it burns oil and probably could use a new drive belt as its maxed out on adjustment
Old 04-18-2012, 09:39 AM
I do not have enough data to answer the poll!!
What is your intent for the machine??
Pulling logs out of the woods = 169
Mowing a larger area = 169
Enjoying a Sunday putt around the yard = Original
Both need work.
My choice is both!!
Old 04-18-2012, 09:46 AM
cubby102's Avatar
Both need work.
My choice is both!!
more or less just to have and mess around with/restore/show type thing, i have my 102 for pushing and pulling stuff it does a good enough job and the 80 mows my yard, i just cant pass up the 169 for the price that im getting it for and the fact that its not exactly the most readily available tractor, and the original mostly for the same reasons (havnt found many of them around here lately within my price ranges) the original is a runner just needs paint and probably re-ring the engine and im sure the 169 would need the same. i would probably have to put the same amount of money in both...that and the original looks cooler
Old 04-18-2012, 11:52 AM
I'm with holding my vote until you post a serial number for the original.
Old 04-18-2012, 11:57 AM
You never know, it could be an early O.
Old 04-18-2012, 12:19 PM
Im holing my vote until i see a 169 serial #. 65000 Originals vs. 4000 169's...keep that in mind.
Old 04-18-2012, 12:21 PM
TheIHMan's Avatar
TheIHMan TheIHMan is offline
I think that you should keep the 169. 169's are a lot harder to find than an O
Old 04-18-2012, 01:31 PM
Unless it's a 3 or 4 digit.
Old 04-18-2012, 01:39 PM
Still, theres more 3 and 4 digit serial #s of Originals then there are 169's. Like Adam said, you can buy Originals all day...169's are the real ticket, and will be worth just as much or more as an Original. Just my .02
Old 04-18-2012, 04:35 PM
That's true!
