Does anyone know what parts other than the electric lift motor would be needed to mount one too a 122? I have the lift motor and assume all I am missing is the mounting hardware, I realise that this was never an option for the 122 but I figured if it came off from another narrow frame it should fit the 122. I have all the tools and equipment to fabricate the hardware if needed, I would only need some picture and measurements!!
Thanks!!!!!
1966 Cub 122, #1 Tiller w/both extensions, Brinly plow & custom grader blade
You would be missing a simple bracket that attaches to the end of the lift. Check out this thread for a suggestion, and a part number for a replacement lift:
http://www.onlycubcadets.net/forum/s...ead.php?t=4869 |
Thanks!!!! I will check it out....
