I'm looking at purchasing a 149 hydro. I am new to IH cubs and need some insight on what to inspect before I make an offer. I will be driving it,of course, but other than checking the fluids and listening to the engine, what else? I know to listen for "roaring" in the spindles when the pto is engaged.
Would some of ya'll provide me with a checklist so I know what I'm looking at? Thanks for taking time to read my post. |
1 - Tire condition, they are a little expensive
2 - Hydraulic functions for the deck 3 - Hydro leaks down the back of the fender pan and around the shifter plate cover can mean leaking relief valves. Around $150 and up if you have to replace both. 4 - Seats and steering wheels tend to be a little pricey 5 - Listen close to the engine at high and low throttle. The ideal condition is if the motor is good and warm while you inspect/listen to it. |
Engine noises and smoke deter me from purchases. The transmission is so bullet proof, a ride usually answers that question.
Leaks can be troublesome. Anything else is far cheaper to fix than worry about, compared to buying a big box 3 year tractor. Expect to have 1/8 to 1/4 turn of slop in the steering, if that isn't there, somebody was nice enough to fix it for you already!! ![]() It would be nice to try it in some tall grass, that is about the only way to test the clutch (also easily fixed!!). So in conclusion, if it don't smoke, no major leaks, and you are not afraid of a couple weekends of tinkering, GET IT!! |
