Go Back   Only Cub Cadets > Off Topic > Gardens, Lawns and Landscapes
Old 04-22-2012, 12:50 PM
Peruvian Peruvian is offline
Default Cultivating rows?
How many folks make their walking rows 36" or more wide to allow dragging a cultivator behind their IHCC for weeding? If not, do you set up crop rows you can drive over? Photos please!
Old 04-22-2012, 01:13 PM
I used my hiller and made my rows wide enough for my BRS to go between using my home made cultivator.
Tomato Section:
I don't have pics of my regular garden section yet. But it is set up the same way. I can use either my cultivator or my disc set between the rows. About 48" between rows.
Old 04-22-2012, 04:07 PM
Merk Merk is offline
I use my cultivator every year:
Old 04-22-2012, 05:12 PM
robpa robpa is offline
I use 32" rows(oc) for the Cub Cadet w. CC 100 cultivators. This is my 1st year using the Cubs, used to use the MF TO35 w old Ferguson 2 row cultivators and had wide rows(42").
Just curious, Are the tires in above photo a bit under inflated?? I tend to overinflate a bit on ags and under on turfs.
CC 126; CC 122; CC1450; Brinley plow; Brinley cultivators, CC front blade; IH 48" peg tooth harrow.
& 1320 Ford New Holland(EEK!!!)
Old 04-22-2012, 07:19 PM
4SPEED's Avatar
4SPEED 4SPEED is offline
this will be my first year using a 2 row. the center knife comes off to cultivate
Doug
Original , 100 , 125 , 582
Old 04-22-2012, 07:20 PM
Thanks for the replies.
What do you do when the crops get too high to drive over?
Old 04-22-2012, 08:40 PM
That's why I made mine wide enough to drive between.
Old 04-22-2012, 08:47 PM
TheIHMan's Avatar
TheIHMan TheIHMan is offline
I put mine about +-4ft so I can run my 1650 with a #2 tiller between the rows
Old 04-22-2012, 09:27 PM
by Peruvian
I use a Troy-Built tiller or a hoe.
Tiller is 20 inches wide.
Old 04-23-2012, 09:02 AM
I also use a Troy Bilt if a hoe wont do it. Hopefully the crops have filled in with foilage enuff to help weed suppresion.
