Old 04-22-2012, 09:27 PM
LiamD's Avatar
LiamD LiamD is offline
Default 1450 The results are sparking!
Hi All,
I recently picked up a 1450 from a friend, he stated he thought that it needed a new starter. I installed a new battery and it runs great. Fast forward two weeks and I noticed that it sounds as if the battery is getting low on charge. Tonight I checked voltage while running at the battery and it is at 13.59 volts seems right. the throttle cable quits, so i remove the side panel and prior too me changing the mounts i notice that the throttle and choke cables have worn into the engine tin work behind the flywheel and the choke cable is arching against the tin. I moved the cable away from it, shut it down and upon trying too restart I notice that the choke cable is now arching at the dash on the outside near the steering wheel. Any suggestions on where too start. A quik once over and I didnt notice any wires even close too the choke cable. Could it be a bad ground by chance? Any opinions are appreciated.
Thanks, Mike
Old 04-22-2012, 09:32 PM
From the manual section here on the forum
Old 04-22-2012, 09:38 PM
LiamD's Avatar
Thanks Jeff,
I have the wiring diagram already, but I appreciate that.
Mike
Old 04-22-2012, 09:41 PM
There is supposed to be a #8 wire from the bolt on the starter mount leading to the chassis.
Is that missing!!??
Old 04-22-2012, 09:49 PM
LiamD's Avatar
Thanks Cadplans,
I will check that but I only noticed one wire on it and it was part of the wiring harness.
I'll check that tomorrow.
Thanks, Mike
Old 04-22-2012, 10:05 PM
2 of mine have a 8 inch wire from the starter mount to the bolt holding the grill shell. It is not in a harness bundle.
Old 04-23-2012, 09:52 AM
jbrewer's Avatar
jbrewer jbrewer is offline
If the dash is fiberglass, I think arcing to ground thru the choke/carb cable makes sense. (ISO mounts do more than insulate from vibration!)
John
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 04-23-2012, 04:43 PM
John
I agree!! The choke cable would give off a nice glow during starting for a while!!
Old 05-02-2015, 06:28 AM
Gijazbo's Avatar
Gijazbo Gijazbo is offline
I had the same exact issue on rebuild. Per some recomendations here, i ran a ground from the starter bolt straight back to the negative terminal on the battery.
