pulled the carb, soaked it and did a rebuild. floats in good floaty shape. put her back together and fuel was coming from the air cleaner. so i adjusted the tab on the float to make it ride lower. its at a pretty good angle down now. it stopped the leak. rode it around and fine tuned her. parked her and came back a few hours later and still no leaks. thought i had it. this morning though it was bad news. leaking out the air cleaner again. how much of an angle can i put on this float? as much as it takes before it starts to starve for fuel maybe?
Many people will tell you the float needs to be "level" or whatever the gauge requires.
The fuel level in the bowl effects engine performance. I would bet there is a different problem. Dirt, old rubber from a deteriorated line, defective needle or seat, the list goes on and on. Sorry, I do not think I could be lucky enough to hit the one answer. |
has the seat and needle been cleaned/replaced during the rebuild.
John
the float valve and seat is new. i noticed that the new float valve has a rubber tip on it where it contacts the float tab. new seals, new high rev needle, and throttle bushing. how tight should the float valve seat be in the carb body. i have it pretty snug right now.
It shouldn't need to be that tight.. .I think there's an oring around it isn't there?
You sure that float is good? John
Mine was leaking gas and I discovered that my fuel bowl breather drilling was clogged. Might be something easy to look at.
CCC 784 w/ Triple Hydraulics IH 982 Cub Cadet Commercial H1748 Walk-Behind 50C Deck 42" Hydraulic Angle Front Blade 41" IH Rear Blade QA42A Snowthrower |
there is an o-ring and it is made of metal same as the one that came out. all holes were blown out with air. i will check the float again and make sure there is nothing stuck in the float valve.
![]() Quote:
![]() Quote:
Snug the float valve seat. Don't over tighten. I've seen em stripped out by PO's with a little RTV applied ![]() ![]() Dang Matt, You type faster than me, LOL............
Josh Diesel Cub Cadets........... |
k, that is exactly what is going on. its frickin in there backwards. boy.... do i feel like a schmuck! thanx for clearing this up fellas.
