My 122 engine smokes above the dip stick after running about an hour. it looks like it is comming out of a breather of some sort. suggestions on how to fix
Ploughboy |
My 128 motor did that. I ended up tearing it down and found a ring stuck and a lot of carbon build up around the valves and piston and the cylinder was pretty much out of spec. Had to bore it .010 over.
You could try using some Marvel Mystery Oil in your fuel and a bit in the crankcase. MMO can sometimes get stuck rings and valves loosened up. It may take a few mowings to get it worked in. If that doesn't help, then you may need to pull the head and take a look at what is going on inside the cylinder.
DWayne 1973: 128, ag tires, 3pt. lift, spring assist, lights, 42" Deck 10" moldboard plow 2016 XT1 42" deck 18HP |
