Old 04-29-2012, 09:27 PM
HawkEyeEarl HawkEyeEarl is offline
Default 1650 rim question -- added pictures of the rims
My rims have something like o-15741 or c-15741 on them.
also there is EWO or EWC and maybe 12x7 1A on them
valve stems are turned in to tractor body - concave to outside
the would not fit any other way as best I see it.
brakes will not fit in the concave...
tires are old 23/8.5x12 carlise turf saver
are these the original rims?
serial places tractor at early 1977 I believe
It looks like the concave could hold a lot of weight before extending outside the rim.
Thanks
Earl
Old 04-29-2012, 10:25 PM
bocephus1991's Avatar
I don't believe those are original rims,that doesn't sound like a IH part number. The rim size should be 12x8 , could have been special order or or a PO change. The tires originally were goodyears.My 1200 has 23-10.5x12 tires.
Brian
Old 04-30-2012, 06:21 AM
How about some pictures..........
Old 04-30-2012, 06:23 AM
Default original rims for 1650
bocephus1991
I had wondered because others elswhere here had something about valve stems on the outside for a 1650. If that is right then my rims must not be original, since I tried to turn them around and they would not fit.
Roland Bedell
I will take some pictures soon and post here.
Thanks for yall's reply
Earl
Old 04-30-2012, 07:56 AM
Here is what the 1650 rolled out of the factory with......
Old 05-01-2012, 06:03 AM
Default 1650 factory tires
Roland
I wanted to know what they rolled from the factory with.
I appreciate you posting it.
I have 23x8.5x12 and for original should have 23x10.5x12 on proper rims.
I need to locate some kentucky feller that has some original parts, sometime, close by.
Thanks
Earl
Old 05-05-2012, 07:49 AM
Default pictures of 1650 non original rims
I took some pictures of the tractors as I said.
Old 05-05-2012, 07:56 AM
Default more pictures while I am at it
More pictures
Old 05-05-2012, 08:05 AM
Default the last pictures
I need to hook up my 3 point hitch
Old 05-05-2012, 08:42 AM
TheIHMan's Avatar
TheIHMan TheIHMan is offline
Yeah those are not original rims, The tube plug (where you air it up at(I cant remember what it is called right now)) should be on the outside of the rim instead of the inside. So those are not the right rims.
