Old 05-03-2012, 08:54 AM
Kelpie's Avatar
Kelpie Kelpie is offline
Default Mower Deck Baffle
Hey there,
I have three 38 inch mower decks and they all need the baffle. Was going to go to the steel yard and buy some stock to make them, but I have no way of bending them to the proper dimensions. Does anyone know how I would go about doing this?
Mine are all completely gone, so I don't even know what radius to use while bending and I really don't want to guess.
1964 Model 70 that Dad bought new. Lights, fenders, creeper, 38 inch deck, Brinly plow, sleeve hitch, and lift assist.
Old 05-03-2012, 08:59 AM
Originally Posted by Kelpie View Post
Hey there,
I wonder if you could tack weld one end and bend it and tack as you go. The baffles are about 1" shy of the end of the blades. Get the area clean and take a marker and hold it about 1" from the end of the blades and turn each blade to make your outlines until the blades over lap. Then weld the baffles to the lines.
Old 05-03-2012, 09:21 AM
jkier's Avatar
jkier jkier is offline
That's exactly how I did mine, just used some spare flat stock.
I could still see the remnants of the original baffle welds, started at one side, tacked and worked the flat stock to the other side.
106 Needs a clutch-------107 (Lent to my brother)
123 w/hydro lift & qa36--126 w/creeper and lift
127 restored--------------129 50" mowin machine
129 w/hydro lift-----------147 plow horse w/tiller
149 auction score---------782 KT17SII
Old 05-03-2012, 09:36 AM
The steel would be easy to bend.
Just pre-bend it to the approximate shape. Weld the end and bend to the required location as you continue "adjust bending" through the arc.
Do not try to have a continuous weld bead from one end to the other.
A continuous weld will cause a lot of thermal distortion.
Try to just add the number and length of the original welds.
Old 05-03-2012, 08:47 PM
aarolar aarolar is offline
Just how important are these baffles the deck on my 805 doesn't have them and seems to cut fine, the one that goes under my 124 still has them. I was debating on putting them back in the 805 but it cuts so good I was wondering why I should bother.
Old 05-03-2012, 10:28 PM
With them it will improve the cut and discharge.
Old 05-03-2012, 10:32 PM
Kelpie's Avatar
I may need to try something different because I have never welded anything and don't have a welder. Probably will have to find someone who can weld it for me.
Anyone know the thickness and height of stock to use?
Old 06-03-2012, 10:48 PM
Kelpie's Avatar
I got some flat stock and am making a pattern to bend it. I found a large roller I can use to help bend it.
Old 06-06-2012, 09:28 PM
Kelpie's Avatar
The flat stock I have is 2 inches wide. Is that going to be too tall for the deck? It's almost as tall as the deck is.
Old 06-06-2012, 09:47 PM
nikster's Avatar
nikster nikster is offline
Mower baffles are the talk of the week.
Nik,
