Old 05-03-2012, 10:30 PM
dsmithjr's Avatar
dsmithjr dsmithjr is offline
Default 2072 resto mod
What started out as a simple clean and polish has turned into a resto mod on my 2072. I say resto mod because I am not going for factory correct restoration and intend to do some mods. I plan to set the 2072 up for gardening and yard work but no mowing. Got the engine cleaned and repainted. I am going to do a quickie spray on the frame and fenders.
Here are some pictures of the progress.
Engine Pulled
Frame cleaned up
Some fresh paint on the engine
Don Smith
Old 05-03-2012, 10:34 PM
Looks great!
Old 05-04-2012, 12:03 PM
Nice work. Looking forward to your progress.
Old 05-04-2012, 04:36 PM
CCSuperMan's Avatar
Thumbs up
That's a nice super .
Old 05-04-2012, 04:41 PM
dsmithjr's Avatar
Thanks Super! You have some nice looking supers also
Don Smith
Old 05-04-2012, 05:03 PM
CCSuperMan's Avatar
Im down to 1 1872 ! Been a wild ride over these past 2 years . I've been thru 6 of them .
Old 05-04-2012, 09:58 PM
dsmithjr's Avatar
rkeithley, Thanks for the reply. Basically I just wanted the engine clean and $5 bucks worth of rattle can high temp paint did the trick. I plan on fixing this tractor just to play with around the yard. Speaking of engine temps I am thinking about adding a temp gauge and oil gauge just for a good mod anybody got tips on doing this?
Don Smith
Old 05-04-2012, 11:46 PM
inspectorudy's Avatar
Default oil pressure gauge
I took out my hour meter and replaced it with an oil pressure gauge. On air cooled motors the oil temp is really what you are concerned with anyway. I put the hour meter under the hood next to the oil filter. After all we don't actually watch the meter while we are running the tractor do we and I never figured out why we had it on the panel instead of oil pressure or oil temp.? Here are the pictures of my gauge and the fitting that sends the pressure to the gauge as well as the hour meter.
BTW, as the temp rises the oil pressure will drop to a lower level. I do not know what this temp is but on a hot day it never goes below about 35psi.
1811 Hydro
Old 05-05-2012, 09:35 AM
123Pokey321 123Pokey321 is offline
dsmithjr, what other mods do you have planned for the resto?
Old 05-05-2012, 11:27 PM
dsmithjr's Avatar
Rudy, Thanks for the pictures that whats I'm looking at doing. My hour meter doesn't work even though there is power to it. I think Ill do the same and move mine under the hood and put the oil pressure there. It looks like you added a fitting at the filter to supply pressure to your gauge? I will have to check oil temp gauges to see how that can be set up and located on the dash.
Update on progress. Did more cleaning on the frame and some further dis assembly. Sprayed the fire wall black. Sprayed the rear axle black. Sanded and primer-ed a few spots on the frame. Sanded the battery tray and sprayed it with black rubberized undercoating on the battery side and just black on the bottom.Started working on the fenders bending out some dents. Took some pictures Ill upload later.
Don Smith
