Has anybody been able to cross over 487045R2 which is the long belt for the narrow front Cub Cadets to run the #1 tiller?
Adam 102 Cub Cadet w 42in mower and rear lift 125 Cub Cadet w 48in mowerand rear lift, #1 tiller and brinly plow 147 Cub Cadet w 48in mower and rear lift 147 Cub Cadet w 48in mower '62 Farmall 504, and 404 '64 Hi-Utility 606, '58 Hi-Utility 460 '56 100 w fast hitch email]adam.brock@nortrax.com[/email] |
The belt I use on both my 122 and 125 using my 1A tiller is NAPA belt # AX144
I am NOT sure if that's the same belt you need |
![]() Quote:
Google is your friend |
Also us the 1/2 x 144. Bob
What kind of luck are you guys having with the cross referenced belts? I had an aftermarket one and it broke after two seasons. Bought a cub belt, alittle more pricey ($85), but it's lasted 4 seasons and still looks like new.
Josh Diesel Cub Cadets........... |
We bought a Kevlar belt from a local store for $40. It was 147in long (on the 1650 with a #2 tiller)
Adam Current Workhorses: 1977 1650, Sleeve hitch, #2 tiller; 1985 782, QA 42A snowblower, 50'' deck, 42'' blade, Ags, IH Wheel weights; 197? 1250; 1976 1250, hydraulic lift, 44'' deck, 54'' blade (currently needing a engine) Current Projects: 1970 107, Sleeve hitch, 42'' deck, Tri Ribs, 8'' Brinley Plow Family owns over 30 tractors, 7 combines, 2 bulldozers, 2 mid size trucks, 1 semi, too many truck and scouts to count including parts, and 3 pulling tractors. All vintage IH. |
The NF use a shorter belt the WF and QL's.
Thanks Guys.....I knew I could count on getting an answer here. Hopefully I will be back up and farming tomorrow...Thanks again
