Old 05-09-2012, 07:11 PM
cub71 cub71 is offline
Default Can't get motor to run right.
Well I got my K241 (10HP) kohler in my 71 with everything hooked up and got it started, but I am unable to get the carburator adjusted right. I took it all apart soaked it in carb cleaner, blew everything out with air put it back on and still no luck. The motor runs but it backfires a lot and "skips" but still runs fine. The muffler that I got with it is all rotted out so it is bacically straight through. Is is possible that the empy muffler is the reason for my troubles, and if so I really don't want to spen the money on a new one, so would a small stack backfire also or could I just readjust the carb to the stack and it run smooth?
Old 05-09-2012, 07:26 PM
PaulS's Avatar
PaulS PaulS is offline
cub 71 you might want to check the timing too.
Old 05-09-2012, 07:31 PM
I checked my timing because I had to get it timed before it would even start thats why I'm stumped on whats wrong
Old 05-09-2012, 07:35 PM
The muffler shouldn't cause that kind of issue. Have you replaced the points and condenser?
Old 05-09-2012, 08:07 PM
the points, coil, and condenser are off of my 7HP kohler and that one ran fine.
Old 05-09-2012, 08:38 PM
I got a K321 running and it ran like you described.
The condenser wire was disconnected.
It had a pretty blue spark without the condenser.
Old 05-09-2012, 09:03 PM
1) Carb-- Did you feel for air coming out all the passages? I use a carb cleaner to spray and look for liquid coming out each passage.
http://onlycubcadets.net/forum/showt...=carb+settings
post 2 has the correct carb settings for the needles
2) points-- verify .020 gap or better yet, use a timing light to set them. Also make sure they are CLEAN
Double check wiring and connections.
Old 05-09-2012, 10:53 PM
Guesse what!? the condensor had a bad ground. cleaned the metal bar and it cleared right out. However I do want to get a tune up kit for my motor to really make her purrr like a kitten.
Old 05-10-2012, 07:50 AM
yesmar74's Avatar
yesmar74 yesmar74 is offline
Just a thought. Make sure the condenser is on the negitve post. It will run on the positive but with symptoms as you discribed.
1973 149 with 44" Deck, 782 with Simms cab, 1966 102 with 38" deck, 50" deck, 5 42" Blade, Brinly 8" 3- point Plow, Brinly 10' Sleeve hitch Plow, Brinly 12' 3-point Plow, 782 Pile, 2-38' Decks, QA-42A,1650 Roller, QA42 Thrower, Kubota BX 2360, 1970 IH one ton 4x4, one 1959 farmall cub restored, two 1949 farmall cub projects, cub grader blade, 5 sickle bar mowers , 1 set cutivators , 1 fast hitch plow, 1. 1950s IH hay rake
